Ampacity derating in Panduit wire duct
I am looking at chapter 12 in NFPA79 with regard to sizing conductors. I understand that Table 12.5.5(b) must be used to adjust ampacity when there are many conductors in a raceway or cable. My confusion is whether this also applies to conductors contained in slotted wiring duct. I was under the impression that since the slotted ducts allow airflow that they would not be considered a raceway.
However 12.5.5 says "Sizing of conductors within control enclosures in wiring harnesses or wiring channels shall be based on the ampacity in cable or raceway."
The verbiage is a little unclear to me. Am I supposed to treat conductors in a Panduit style wire duct like a raceway or cable?
Thanks in advance.
Thanks in advance.
RE: Ampacity derating in Panduit wire duct
I always treat them like in raceway -- the heating effect is not amplified so much by how the air circulates as it is by the heating effect of all the conductors' individual contributions when laid in a bundle. They're touching each other, and if there are enough in your wire duct, some will be completely surrounded by other current-carrying conductors.
My opinion anyway -- let's see who else pitches in.
Good on ya,
Goober Dave
However, if the conductors are loaded I would consider Panduit to be a raceway and derate accordingly.
Bill
"Why not the best?"
Jimmy Carter
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
