PCDs in drawings
PCDs in drawings
PCDs in drawings
I'm 3 months into teaching myself Wildfire 2.
Can someone tell me how I get the a PCD centreline to show on the drawing?
For example I want to model 3 holes M3 equi-spaced on a 30mm PCD, I would:
  • Insert an M3 hole, placement is diameter using a datum axis and datum plane to define the position
  • Create a circular array, using the reference axis as the datum, with 3 features.
That gives me all the dimensions and centrelines of the holes but no pcd centreline, what am I missing?
Thanks in advance
RE: PCDs in drawings
Drawing option radial_pattern_axis_circle yes
Set the drawing option, still no joy. I'm working on the theory that it would appear using View "Show / Erase" and Axis?
Correct
Hmm, nothing I need to set when I'm creating the array?
