Foam cylinder with metal plate inside
I need to produce a closed cell plastic foam cylinder of height about 6 mm and diameter 2 mm. The trick is that we would need to insert a aluminium plate inside this cylinder (width 1.5 mm and height 4 mm).
I have considered two options:
1. Find a company that can put these plates inside the cylinder during their foam process
2. Use two half-cylinders and somehow combine (how?) the parts when the plate is between them.
I haven't considered gluing as we need to produce tens of thousands of these cylinders. If someone can guide me to a manufacturing company or process that can handle these requirements, it would help me a lot.
RE: Foam cylinder with metal plate inside
Must it be closed cell foam? How about say, PP or PE with a good dose of blowing agent in it? If so, could easily be injection moulded, either robot insertion of parts into a multi-cavity tool or manually (at added cost, I guess, unless low-wage area!)
H
www.tynevalleyplastics.co.uk
With a name like Oseania, it sounds like you could be Aussie or Kiwi.
I know a moulder in Sydney who already over moulds steel bar with foamed PP to encapsulate the steel to reasonably accurately controlled thickness.
I can put you in contact if you are interested.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Thanks. I am talking to couple of manufacturers and hopefully someone is able to coat the plate with foam. Unfortunately the foam has to be closed cell.
I know Reiss Industries (in watertown Wisconsin) does that kind of "overmold" of foam. I've seen it in an application for an OB-GYN stirrup... they needed the strength of the metal, but the softness (and with the external skin... the chemical resistance) of a closed cell foam.
They don't have a website which i balked at, but after visited their facility I can see that they're legit.
If you want something with a website, maybe check out Bergad.
Chris Loughnane - Product Design
http://www.pdnotebook.com
http://www.twitter.com/DesignNotebook
