CATIA V5R18 drafting problem!
Hi guys,
Im having problem with drafting in Catia on one PC. On one is working perfectly, using mono*** fonts and showing image sharpely, but on the another is using SSS2 fonts as default and forcing it always...and image is a bit blurry with thicker lines...line edges are smoother somehow. Both pc's have XP sp3 and same family nvidia graphic cards.
I log in as admin and change default font and is good when i create a new drafting docment, but when i open old ones it comes back SSS2.
Did anyone had issue like this?
Thanks for reply,
Miles
RE: CATIA V5R18 drafting problem!
For the old documents the standards are stored with the document.  With the document open, you have to go to file, page setup, then you should see an update button next to the drafting standard.  Use that.
Thanks, but thats not it. What it seems to be is that graphic card is working at the peak of voltage so it is causing display issues?! We moved PC in different office and works fine, move it back and graphic issues are back. Ill upload screenshots on both occasions so you will see this X-files issue :)
thanks for reply
Solved... motherboard p7p55pro driver/graphic driver issue...
