"Extrude Cut" in DesignModeler 12.1
I come from Pro/E and Solidworks usage. And making an extrusion cut is easy but I just can't find this option in DesignModeler 12.1.
For example, I want to cut a cylindrical hole halfway through a bigger cylinder. I draw the bigger cylinder then click generate. Then when I try to draw another smaller cicle concentric to the cylinder on the same plane, it automatically cuts a hole through the entire cylinder.
I know I can just draw it out then revolve it, but I just want to dig a hole. ;)
So what am I doing wrong?
RE: "Extrude Cut" in DesignModeler 12.1
Here's the result that I keep getting in the link. Either it leaves the outer part alone, or it takes out the outer part. But the inner part is always extruded through all.
http://img718.imageshack.us/i/failedextrude.png/
Issues solved.
