6061-T6 vs 6063-T52 Aluminum
I apologize as I didn't know exactly where to post this, so hopefully it is in the correct forum.
I encountered a situation where a 6061-T6 Aluminum tube [2.5 Dia – Schedule 40 (3/16" wall thickness] supposedly cannot be bent to the 8" radius that was specified. The contractor has asked to use 6063-T52 aluminum in order to bend it to the specified radius. Based on all the information I could find, the 6063-T52 is more of an "architectural" grade and is not nearly as strong as the 6061-T6. At the same time, this tube only has to support approximately a 100 lb at the end of this "j-type" configuration so even though 6063-T52 isn't as strong, I don't think using it will be a problem.
Anyone have any thoughts as to substituting one grade for another? I may be missing something and I only have a few years experience to fall back on so any help would be appreciated.
Thanks in advance.
Thanks in advance.
RE: 6061-T6 vs 6063-T52 Aluminum
2) bend in O condition and heat treat to T6 or T3
Tobalcane
"If you avoid failure, you also avoid success."
Once that's done and assuming it's OK then you can worry about other factors.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Tobalcane
