Braking of a spinning disc
Hi
Hopefully i have put this in the right forum, thinking the application i want is similar to braking an automotive vehicle or similar.
I have a vertical disc of 0.6m Ø weighing about 15 Kg. This has coil loaded onto it (via a ctr spindle) which is pulled off, thus rotating the disc. The coil weighs about 10Kg and the OD is 0.6m Ø. (Obviously this reduces as the coil is unwound but i only want to know the max. worst case value.) The speed of the 'puller' is max 30m/min.
I want to add a brake onto the shaft to stop the spinning disc, time to stop in say 1 sec (i.e emergency situation). How can i work out the torque of the disc to compare with the brake torque values to ensure i spec the right one? Obviously i will approach a supplier for their input, but i would like to try to work it out and understand the maths myself. I dont care about the fact the disc will speed up or the OD of the product will reduce as it is pulled as if the brake can stop in the worst case sceanrio, then all bases should be covered.
Any help is greatly appreciated,
Jim
Jim
RE: Braking of a spinning disc
Dan - Owner
http://www.Hi-TecDesigns.com
Cheers
Greg Locock
Cheers
Greg Locock
If you know the inertia in lbs-ft and the speed in rpm then the torque in ft-lbs is calculated as
T = Inertia X Speed / (308 x decel time)
At least I think I got that right. I didn' spend to much time on it.
It should be simple to calculate the rotating speed given the circumference and the product take off speed. To calculate a rough inertial this sounds like a couple of cylinders, the disk and the product, so the forula for that is simple too.
Although, I am a fan of the pokes.
Fe
That said, I see a lot of threads that ask questions so simplistic to anyone with real engineering knowledge or training that I take the position that if their understanding is at the level of their question, that level of understanding won't allow them to understand an answer that I would give, so I don't get involved.
A lot of good dedicated members got involved once in a thread where it turned out that the poster was a glass blowing artist who wanted to generate power and light the world with the waste heat from his glass furnace. What he wasted was the time of a lot of good engineers who didn't pick up on his level of ignorance and spent a lot of valuable time trying to propose solutions to someone who ended up being incapable of understanding them.
So after I get this rant submitted I think I'll go back up and give Dan a star for his initial answer.
rmw
Greg thank you though for at least showing me a route to the problem.
I have one question though, and so prepare to open myself to more abuse. You calculated the angular velocity (omega) presumably into rad/m ? I thought SI unit of this should be rad/s...i only seem to be able to get t=1.873Nm
Open to comments
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Are you freakin' kidding me?!
Dan - Owner
TTFN
http://f
http://f
TTFN
So yes IRstuff and I agree, not very much is the answer.
As a comparison, operating a butterfly nut with your thumb and forefinger will generate about that much torque.
Cheers
Greg Locock
That's one of the beauties of using units in Mathcad; it tends to keep things straighter...
TTFN
Maybe that jimsmiff is not an engineer, i don't know and i don't care. I still have respect for his willingness to learn and improve on a personal level.
Why the whining? Replying is not manditory i believe.
I notice neither has really served this community all that much, but you feel you have the right to tell long serving very active members who contribute a lot that they should support the breaking of site rules.
The rules are for a reason. Those reasons should be obvious.
Pat
for site rules
