Wheel Load for a loaded semi
I'm looking for an approximate value to use for a belly dump semi with a 43' trailer loaded with lime (rock). I believe it was a dual-axle trailer.
I'm looking for the load to each axle or the load applied by the wheels. I live in the upper midwest , if that matters.
A conservative estimation or a source to look up the load would be greatly appreciated.
RE: Wheel Load for a loaded semi
