pre-treatment of 90/10 cupro-nickel tubes with ferrous sulphate.
Hi All,
I'm wondering if anyone has any helpful information about pre-treated cupro-nickel condenser tubes. That is, tubes that have been given a ferrous sulphate treatment prior to installation in an older condenser, to build up a bore scale and prevent pitting.
I'm having trouble finding information about the product and am wondering if there is any benefit in using the pre-treated tube as opposed to just doing some dosing treatments after installation of clean tube.
Thanks!
Thanks!
RE: pre-treatment of 90/10 cupro-nickel tubes with ferrous sulphate.
The real key is that the water that the tubes see at first must be clean, even if that means filling the condenser with potable water and using a small recirculation pump.
This will allow the alloy to form its natural patina.
Plymouth Tube
The real key is simply to make sure that flowing clean water is sued during the first few days of exposure. If your cooling water is bad then fill the condenser with potable water and ferrous sulfate before you start running.
Plymouth Tube
