Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
Thanks so much for having a place for us propeller heads to hang out and chat.
Geography
scottneh (Aeronautics)
15 Jun 10 22:40
Hello,  has anyone simulated supersonic flow in UG/NX?  I have a fairly simple flat plate with a small protrusion.  The simulation runs well up to mach 1 or so.  when I try to run it at mach 1.08 it crashes.  I talked with Maya tech support (they make the CFD package for UG) and they told me that the software isn't tailored for flows with "external shocks".  The problem is that I am simulating flow through an arbitrary fluid volume which could be from the inside of a duct or inlet so from that perspective what's an "external shock"?
If anyone has done any simulation of supersonic flow in UG I would really appreciate any help you can offer.  The up loaded picture is a close up of my model at Mach 1.
Scott
btrueblood (Mechanical)
16 Jun 10 12:53
The solver equations and methodology for CFD change across Mach 1, sounds like their embedded solver is an elliptical solver (subsonic) only, and can't handle the hyperbolic (supersonic) flow field.
16 Jun 10 15:06
Thanks for your response.  They advertise being able to run supersonic flow simulations and they have an inlet condition for supersonic flow.  So I'm thinking that there must be some sort of condition under which their solver will work.
Close Box
Join Eng-Tips® Today!
Join Us             Close
