meggaring cable
meggaring cable
i have a 3 conductor 12 awg 600volt rated cable feeding a motor. the leads have been cleared at either end the grounds are still connected I meggared at 500volts and have 2000m ohms between wires and 5m ohms from each wire to ground is this a good cable?
RE: meggaring cable
