Fill pattern in Soliedge
I am a previous Solidworks user, who used the fill pattern frequently to create pinbloc heatsinks relatively quickly.
However being very new to Solidedge, i cannot seemt to get my head around patterning, is a fill pattern possible within Solidedge?
RE: Fill pattern in Soliedge
I can't recall the details but there are settings to change up on the ribbon bar I think.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
When you define the pattern sketch, change the Fit option in the Command bar to Fill. You will then be able to define the pattern occurrence spacing for both X and Y.
Jon Sutcliffe / Solid Mastermind
The Solid Edge Community. Video training sessions, best practice documents, process maps and interactive training http://www.SolidMastermind.com
