Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site was well structured and I found what I was looking for in about 2 minutes. I am looking forward to participating with you in the future..."
Geography
bhart192 (Civil/Environmental)
15 Jun 10 11:19
we have a existing hollow block wall ,non load bearing partition, we need to create opening at one end ,the opening span will have  16' span we intend to put a WF8*24  for a lintel ,on one side  of the opening the block wall will be 16" long where it intersects the exterior bldg wall.the opening will be 8.67' high  ,thus the end of the lintel will be bearing on a section of wall 8.67" high by 16" in lenght ,where can I find data to check for load carrying capacity of this small column like section of wall.
MiketheEngineer (Structural)
15 Jun 10 11:23
Hire a structural engineer.  There may be more going on than you think.  This may in fact be a shear wall of sorts.
W/O looking at the whole building - any guess would be uneducated.
JAE (Structural)
15 Jun 10 13:13
ditto.  If you don't know what you are doing then get someone who does.
brickmason (Structural)
12 Aug 10 18:24
I dont know much about the iron you plan to use, but the block should hold with no problem, especially since it is a non load bearing wall. i suggest that you fill the block pier at both ends of the opening fully with grout, also embed a steel plate in the concrete at both ends of the iron so that it can be welded down to the plate.
Ron (Structural)
12 Aug 10 20:07
Careful there Brickmason...interior walls have lateral loads on them as well.
Get a structural engineer involved. JAE and Mike are exactly right.
csd72 (Structural)
16 Aug 10 11:00
Ditto
Close Box
Join Eng-Tips® Today!
Join Us             Close
