Coating on stainless steel
I am looking a coating/plating for stainless steel to add an extra layer of protection in a corrosive environment. The part is a 1/2 x 3/4 inch fitting, it is exposed to salt water and bleach, and the temperature exposed to gets to about 175 degrees F. I need to find a coating that is also abrasion resistant. I've never heard of coating stainless, but I guess the idea is that stainless can rust and the coating will add extra protection. If a little scratches/wears off, you still have the stainless beneath the coating. I suggested passivation, but they want the coating. If anyone has any ideas or suggestions to help me get started, I'd appreciate it. Thanks in advance.
RE: Coating on stainless steel
Electro-Coatings
http://www.electro-coatings.com
On the downside it won't help at all with the abrasion.
I agree with you, my first pass would have been passivation.
