Trapezoidal Section for Beam in Etabs
Hi everyone,
I've to ask whether, in etabs, we can assign a trapezoidal section to a beam such that, in addition to anlaysis, it also designs that section. I've used SD section but it designs the section for columns only. If beam section is used using SD section property, it only analyzes it and design is not carried out.
Need your help.
Thanks.
Need your help.
Thanks.
RE: Trapezoidal Section for Beam in Etabs
I'm waiting for my question to be answered by you friends. Kindly suggest me a solution for the problem. I shall be very kindful to all of you.
Regards.
