NX Expresssion/Function Question (ug_excel_read)
I have some parts in UG NX4 containing expressions that are updated from an external spreadsheet.  When I use the function "ug_excel_read" I am asked to specify a spreadsheet.  When I use the menu to locate the spreadsheet it automatically populates the file path into the function formula.  This works fine as long as my spreadsheet stays in the same location.  If I move the spreadsheet to a different folder or location everything blows up.  Is there a way to either make the file path a variable that I can change throughout all of the expressions in my part or can I leave it blank and have it default to searching for the spreadsheet in my working directory?  All of this is assuming I am working in native UG right now.  If more explanation of my problem or what I am looking for is needed, please let me know.  Any advice is appreciated!
RE: NX Expresssion/Function Question (ug_excel_read)
No, the path needs to explicit and up-to-date to work.
That being said, what exactly are you using the 'external' spreadsheet for?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Is it possible to store the spreadsheet on the same drive/folder that your NX files are resident in?
Thanks for the replies!  John, I have an assembly that I am scaling based off of some design calculations and macros in an external spreadsheet.  All the calculations are performed in the spreadsheet, it is saved, and then I refresh my parts in UG with a macro to get the new geometry.  My problem is that sometimes I need to allow another user to utilize my spreadsheet and UG parts.  If they copy the files to a folder on their machine, all the file paths in all of the parts need to be changed.  If there is not a way to avoid this, is there a better way to accomplish what I'm trying to do?  Thanks!
Is there a way I could put the parts and spreadsheet in Teamcenter to allow others access and solve my problem?
Actually the Teamcenter solution would be the best long term one if this is going to be a common part of your workflow.
John R. Baker, P.E.
Industry Sector
Cypress, CA
That is true John. I wish our IT system allowed that. Even their knowing that having the spreadsheet stored in a vulnerable area...MY USER Folder, they seem to be intransigent.
