laminating existing tank shells with new sheet steel
Is there any restriction on welding a thin gauge less corrosive sheet material over the existing tank shell and bottom. This would be done with lap welds and plug welds.
Thanks in advance
Thanks in advance
RE: laminating existing tank shells with new sheet steel
Strip lining is a short term solution and a long term PITA for the inspection, plant engineering, and maintenance crews.
No restriction on the concept from a Codes or Standards perspective that I know of, though.
jt
Is there more to this story ?
2. I'm a tanky and not a painter.
Thanks for the response.
