How to weld titanium shimstock
Looking for a little help on my application.
I need to create cylinders out of 0.003" thick titanium by wrapping the material around a form (solid cylinder with a groove cut out for weld tool) and then spot welding the overlapping ends.
The specs are: 0.003" thick titanium (MIL-T-9046, COMP CP-1, GRADE 4).
Currently, even our lowest setting on our smallest welder is easily burning holes through it. A little research has lead me to believe I need to use a small "dental welder" or "hobby welder" but would like the advice of the members here.
Anybody come across something like this? Anyone recomend a machine or process?
Steve
Steve
RE: How to weld titanium shimstock
Ti is normally not acceptable for use above 400 deg C because it will exhibit very poor oxidation resistance. Why was this material selected?
http://www.mpdwelding.com/microtig.htm
http:
I did read something somewhere about spotwelding Niobium underwater, might be applicable to Ti as well...then again, might be a good way to electrocute somebody. Control of heat input via micro-tig and pulsed power supplies is going to help a bunch. In the end, getting the heat out of the Titanium is going to be the tricky part for such a thin gauge of material.
Our welder has a micro-setup but it is slow and expensive. I was hoping for something a little easier/dirtier that we can pump out lots of these. I don't want to get tunnel vision, but I envisioned a mini spotwelder to perform the job, however I'm not a welding expert so the recommendations are appreciated.
If you have good clean steady power from you welding power supply and an older welder. good eye sight, you might be able to use a resistance box to get the current down. this might not work for your material and thickness. I've seen such a rig work with 0.008" SS, much easier to weld than Ti.
I would also contact Weld Logic concerning your production problem. They should be able to give you some very specific advice and they may have some surplus equipment.
http://www.weldlogic.com/index.html
We did it in a glove box to minimize oxygen pick up.
If you don't need full welds in these then you could make a series of 1/2" long stitch welds quickly.
You need to have no oxygen present. You might want to play with spot welding inside an argon purged glove box.
Plymouth Tube
