Update View takes too long
Are there any tricks to getting drawing views to update faster in NX 6? I have always noticed that other CAD systems don't seem to struggle with this as NX does. Have a view that takes 5 minutes to update. Another user has one that takes much longer, probably over an hour but don't know for sure because he always kills the application because he can't wait any longer.
RE: Update View takes too long
While neither of these will have any impact on how long it takes to update Drawing views, they will allow you to control exactly when the update does place so that you don't have to wait every time some minor change is made. You can delay the actual update until later (you could even write a simple NX Open program which could be used to update drawings offline).
Also, if you get to a state where you would to delay 100% the updating any anything on a Drawing you can also Extract Edges in each Drawing view and then NOT load the master model and the drawing will remain unchanged from the last time it was updated.
Note that this is one of the areas where multi-core CPU's could offer at least some help since Hidden-Line generation is one of the limited number of areas in NX which is multi-threaded.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
Suggestions:
1) Refile all your part to the correct NX version
2) Part Cleanup on every 3D parts (or at least on the assembly and drawing files).
3) Verify that none of your parts have "consistency" problems (hope you've a Checkmate tool that automatically verify it).
Beppe Grimaldi
SISW Italy
Go to...
Customer Defaults -> Drafting -> View -> Threads
...and toggled OFF the option titled 'True Hidden Line'.
Now don't be too worried that somehow this will cause the hidden line views to be rendered incorrectly or cause them to look weird. This option ONLY effects how symbolic threads are rendered in hidden-line views. For the vast majority of people, turning this OFF will never be noticed in terms of the quality of their plotted images (with a few exceptions, which is why the option is there in the first place, but the conditions where this would be true are very rare and very part and workflow specific), but it COULD improve display performance when updating Drawing Views. However, there is no guarantee, but under the right conditions...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Next, I STEPed the assembly out and recreated a similar view in Solidworks which takes 1 minute and 50 seconds to update. To compare apples to apples I imported the STEP assembly back into NX 6 and created a similar view and it takes only 1 minute and 20 seconds to update. These STEP based views are on 32 bit NX on a different machine.
So... Can somebody explain what the heck NX is doing in the background during the drawing update such that it takes 17 minutes to update the view with the native data? Is it evaluating assembly constraints? WAVE links? etc. If I have unresolved constraints/WAVE links would that affect it? (please say no) What can I try next? I can't even update the view with the native CAD data on the 32 bit machine.
Doc
http://www.goodrich.com
This is a typical problem..we have offshore workers ie.india that dont want to conform to our standards and continually use wave geometry and also use routing operators for simple hoses..adds a huge weight to the file. The software apparently thinks it has to update every link, file, line, spline.. etc etc in the asm EVEN though none of said were involved in the change..i have heard the expression that while waiting for a update on NX a wheel fell off a car out in prototype build area..thus due to a update to something totaly uninvolved..
I recently did a similar test where I created a parasolid of a large assembly and imported that back into NX and SolidWorks. SolidWorks used about 60% of the CPU power and did the view updates about 65% faster than NX did. What gives? We have a lot of down town around here waiting for drawings to update (and yes, we have done all of the previous suggestions the help reduce this).
chuckrow: We have had similar issues with constraints and have been in contact with GTAC about them. We save a large assembly that is fully constrained with no errors, and the next day we open it, only to find some constraints are broken while others have completely disappererd. Very fruststrating.
http://www.eng-tips.com/viewthread.cfm?qid=281143
Proud Member of the Reality-Based Community..
Does anyone know anyone at GTAC that feels our pain? My experience is that big issues like this just don't ever get resolved, we get tired of looking for help, and nothing gets done. The root of this problem is not being identified or addressed or fixed.
All I hear is the ocean.......when I put my mouse to my ear. I was hoping for more.
Thanks for your work on this, BOPdesigner.
When NX4 was very fast on everything, NX6 now goes into update workflows after a lot of actions and the new assembly constraints patterns certainly makes it more terrible.
A lot of complains already in the GTAC database but always the same old same 'will be resolve by code change blabla' when there's simply an answer...
NX6 is really the worst of all UG versions.
We can't ear the ocean here but the infinite silent space.
The changes which we have been making, and continue to make, to improve performance will only be of benefit to you if and when you upgrade to the most recent releases.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I am a 7.5.x.x user now, and am experiencing the same problems with view updating as these other users are experiencing, and have for about a year, now.
All I hear is the ocean.........
If the 'True Hidden Line' option is toggled ON, please toggle it OFF.
John R. Baker, P.E.
Industry Sector
Cypress, CA
2. yup, did a couple of app-shares to confirm. Could not share the parts. By what I read here and elsewhere, there are other parts that were submitted by other users, that are taking way too long to re-draw. Another user at this site complains also, I know it is a big ocean, but I am not alone with this problem.
3. yessir
4. Toggled OFF -- only reccommendation I ever got from GTAC. Did not help.
No progress on this issue for me.
HOWEVER, I did want to make sure everyone knew that the number one voted on topic for drafting during the CIP process was improving large assembly drawing performance. Siemens is now required to devote at least one man year (I think that's right) to addressing this problem. To me this is encouraging, but I'm not holding my breath. I could spend one man year writing a romance novel and it would still turn out like crap (this may be a bad analogy because they're probably all crap, but you get the idea).
There were an overwhelming number of votes for this item so hopefully they get the picture.
Mike Thompson
Mechanical Engineer
www.wagstaff.com
Preferences -> View -> General
...as well as at...
Customer Defaults -> Drafting -> View -> General
...where it's identified as 'Chord Height Tolerance'.
If this value is set to zero (0.00) the system will assign a tolerance based on the size of the view/drawing, however this might be much tighter than it needs to be. I would recommend that you set it to something like 0.01 (or even 0.1) and see if that helps any.
Note that changing the Perference or Customer Default will only effect the next views which are added to a drawing (note that no matter what this setting is, a 'Projected View' will inherit the tolerance of the base view). So if you have an existing drawing, you will need to select the views of interest, press MB1, select 'Style' and then in the General tab change the value of 'Tolerance'. Also note the tolerance used to DISPLAY your drawing on the screen is NOT what is used when the drawing is finally plotted, so it can be much larger, giving you better interactive display performance. Then when it comes time to Plot your drawing, you can supply a totally different 'Tolerance', something more appropriate for your final hardcopy.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Has your recommendation to the user community just changed? I have tried changing this value, and it has not had that effect.
Oh, and that guy looking over my shoulder, that's just the ocean.......
I have investigated the issue quite thorough.
The tips below will speed up the performance somewhat but there is no revolution.
Make sure all options that isn't very required is off. for example, setting the color of the visible lines to a specific color is probably not needed if it is going to be plotted in B/W. ( default = Blue which is an override, set to "none") Same w the color of the hidden lines. etc etc.)
Setting the color / font / width on a couple of hundred thousand objects will need computing power, which in the end sums up.
Make sure that there is nothing interfering or duplicate since that condition requires more computing.
All "fancy" options needs extra computing = extra update time ( example interference curves.)
The View tolerance ( discussed in other thread) has in my perception no major influence on the computing time. Leave the customer default = 0.0 and if something looks wrong, zoom the view to be ~full screen, set it to 0 and OK the View Style. NX will again find a new value since 0 is impossible but very likely the error is gone. ( -yes, the scale is depending on the zoom factor too.)
Watch the Task manager if running 32bit Windows and note if the Ugraf process goes above 1Gb, ( i cannot state a specific number here.)as soon as the computer starts swapping we are talking long process time and /or unfinished updates. 64 Bit computers with "enough" RAM will finish the updating but not run much faster.
If possible, simplify what is about to become a view, black dots on the plotted drawing, doesn't add anything to the process.
( "This minute dot on this drawing showing an entire car is the injection nozzle, yes the dot is the entire nozzle , with threads, holes, engravings and such")
The Hidden line calculation will calculate all objects no matter the size, even those that are too small to become more than a dot on the plotted paper. ( the ability to zoom in on the resulting view and see the details can often fool the user to keep the miniature details.)
Simplifications using Reference Sets and Arrangements.
Imported geometry such as Step files quite often carry problems for the hidden line calculations. Run Examine geometry + manual cleaning + Part cleanup. As noted before, duplicate geometry is difficult to calculate / decide what surface should be visible and which not. Using the Section tool ( Clip work section in 7.5) and the option Show interference is quite handy when searching for duplicates.
I have been recommended to use Extracted Edges. ( Both GTAC and the Drafting Manual Best Practices.) I have not seen any up's or down's using this, apart from the benefits. ( Such as snapping sketches to those objects and opening "Structure Only".)
Tomas
And for what it's worth, there are plans to work on Drafting performance as part of our next development cycle (but that does not mean the next version of NX as that code is all but done), even if it had not gotten the top vote at the recent Users Conference, however that vote should help us get the needed support from our management to commit the resources necessary to get as much improvement as is possible.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Maybe by then the developers will find a better way to calculate the "optimal" value for chord tolerance?
Much of this requires that we make fundamental changes to the way so-called 'lightweight' representations of a model are stored and used by the system when displaying and interacting with models during a session of NX.
Anyone currently running NX 7.5, if you used the OOTB box settings, should have noticed that the display performance for assemblies, when working in many of the non-Drafting modules, is now much better. This is the result of work done at the very lowest levels of NX to assure that not only are we using the these lightweight representations for display of your models, but also that we can work with them in a manner such that you do not have to worry about whether you have an exact versus a 'lightweight' representation available when you need to perform some sore of in-context modeling operation. This is what we would like to have when working in a Drawing as well, being able to leverage as lightweight a representation as possible without having to fully load an exact model to perform everyday Drafting operations as mentioned above.
But getting back to what can be done today, as mentioned by Toost, not including every small or minor part in every view, particularly if you are performing a full hidden-line-removal (NO dashed hidden edges) on your Drawing views. To this end, the judicious use of the...
Assemblies -> Context Control -> Hide Components in View...
...can pay significant dividends when it comes to the time needed to compute the hidden-edge views of large and/or complex assemblies.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Another trick which might help, particularly if the view presented of your assembly is such that if everything 'behind' a certain point was 'hidden' that the Drawing view would still be valid, is to use clipping planes to virtually 'chop-ff' that portion of the model, normal to the axis of the view, which is not seen. To do this, select the view, press MB1, select 'Style' and open the tab titled 'Perspective'. Now set ONLY the 'Back Clipping' plane. Note that this could be a bit tricky as the distance is based on the center of bounding box for the assembly model. However, to give you an idea of what has been 'chopped-off', after enabling the clipping plane, you can 'Expand' the view and rotate it to see exactly where the 'clipping plane' did it's deed.
Another trick is that once a view has been set-up as desired and you're not going to be doing any additional work on it (adding annotations, doing some specific view-dependent editing, changing display options, creating detailed or section views, etc.) you can select the view and set it to be a 'Reference' view (this can be done from the General tab of the view Style dialog). Now even though 'Reference' views are not displayed when you open a drawing, they will be properly rendered when plotted or when a CGM/PDF file is created of the Drawing sheets. It's conceivable that you could set ALL your views to be 'Reference' and only toggle OFF that state for the views that you need to work on when you need to do so, meaning that you only 'pay' for an update when you change the 'Reference' status of a view making it visible again. Granted, this will not help the performance of the original view creation task, but once a view is created and it's not going to need any immediate work, making it a 'Reference' view can help in any subsequent updates that needs to be done as your placing or working with other views on the same drawing sheet.
John R. Baker, P.E.
Industry Sector
Cypress, CA
The problem with the proposed methods are that they can be done on a view that already has been placed, and then the HLR has already happened more or less.
We place the all the views on the sheet without update, ( Only the border is visible since no HLR has run.) then we start the update ( on 64 bit computers) when it is time to leave for the day.
When we come back we can then decide if we want to hide a component or not. ( and again take the update...)
I wonder if the "man-year" has commenced yet, or whether it is all bulls#it....?
One lesson I learned while working with drawings of large assemblies in SolidWorks was to keep the number of views to a minimum. Often I would create seperate drawing files and split the views up between them. This was a pain but better than losing most of my day waiting.
What about the Small Features options? This gives you a percentage factor which eliminates the display of any geometry smaller than that percentage of the overall geometry size. For physically large assemblies of perhaps several feet or larger, features smaller than an inch would be useless.
Another option that I am unsure of its impact on performance is Edges hidden by edges. If it's off, it's not displaying those edges in the back of the view that basically wouldn't show up anyway because of edges in front of them. But does that mean that it takes more time to process whether or not they are invisible? Or more time to generate those edges for the view?
