bolt dimensions
bolt dimensions
ASME B16.5 shows bolt diameters but do not reference the bolt dimensions in detail.
As ASME BPV section VIII, Div. 1, Appendix 2 requests the calculation of the total cross section of the bolt, I'd like to know, where I can find bolt dimension to be used for appendix 2 calculations (core diameter, ...).
Help is appreciated.
RE: bolt dimensions
Check on-line for paper copies of the books, if you don't rust the actual on-line search results.
RE: bolt dimensions
Mike
RE: bolt dimensions
Scroll to the bottom of the page on this link-
ht
desertfox
RE: bolt dimensions
Best regards
boltb7
RE: bolt dimensions
desertfox
RE: bolt dimensions
I've seen lots of folks use the root diameter based area, but do you have a Section VIII paragraph I can refer to which mandates this? It is not necesserely a conservative approach, as the load for the flange design is derived from the area...
jt
RE: bolt dimensions
Well, the rules are what they are.
Mike
RE: bolt dimensions
Thanks! Kind of obvious in retrospect...
But... I think I'll just keep on using tensile area for Ab in 2-5 eqn. (4). Unless I'm grasping at straws. Then I'll take the less conservative Code definition. At the end of the day, App. S says it's not entirely precise anyway.
jt
RE: bolt dimensions
I've always been kind of curious about the origin of Eqn (4). Average of Am and Ab? Huh?
Mike
