Micro Dynamo
Micro Dynamo
Hi, I need a micro dynamo to convert a vertical motion of 1 cm to rotational energy , is there any company u know?
RE: Micro Dynamo
Sell you a string and a pulley?
Yeah, I got that company right out back...
Mike Halloran
Pembroke Pines, FL, USA
RE: Micro Dynamo
Use a crank arm with less than 0.5 cm throw.
Use a magnet moving vertically in a coil with the output powering a small motor.
Use a small pump pumping fluid to an elevated tank from whence it falls over a tiny overshot water wheel which provides the rotational energy.
Bill
"Why not the best?"
Jimmy Carter
