Unscaling Drawings for output to .dxf
We use Radan for the CAM side of our sheet metal factory. We used to use Radan 2D to do our flat patterns etc but now we have upgraded to Solidworks. Some of my models are quite big so flat patterns are often drawn on sheets at scales of 1:20. However when I export to .dxf or .dwg I cannot not get Radan to resize the drawing that it is importing even thought there are settings that supposedly allow me to do so. My Radan vendor says it must be in the way Solidworks scales the sheet. My question is, is it possible to keep the drawing at 1:1 scale all the time and just increase the size of my standard sheet around it or is it possible to somehow un-scale the drawing as it is exported?
RE: Unscaling Drawings for output to .dxf
I don’t know if this will do what you want but worth a try
Morten K. Thillemann
"The attempt and not the deed confounds us."
