content center missing
Hi!
I'm experiencing the same problem described here:
thread790-231722: Content center missing
I moved the Content Center window and when I tried to use it again I could not find it anywhere.
It has properly worked till now. I don't know how to restore the window.
Please CADone (or everyone else), could you tell me wheather or not you solved the problem? And what I should do?
Thank you in advance for your help!
algio
algio
RE: content center missing
Hit Alt+Spacebar
Hit the "M" key
Use your Arrow keys to see if you can get it back on screen.
You may have to play with this a little.
After several attempts (uninstalling and installing again the software) this morning I solved doing exactly what you said :)
