Spline gages- how do they grind them?
Does anybody know how do they grind the internal teeth on small spline gauges? I'm looking at a DIN5480 gage with internal teeth, and the certificate says the errors are in 2 mikrometers, it looks like ground. But how can that be possible. Just out of curiosity...
RE: Spline gages- how do they grind them?
wire cut then lapped
also there are special custom made miniture internal arms with a grinding wheel if the spline is large enough fot it to fit.
driven by means of a belt.
