Override position
Override position
in NX3 the override position was applicable during the reposition component.
Now in NX7 I click on the sub-component and with RMB 'Override position' command.
After that I tried to add mates at the first level and on the sub-assembly level, but I can't obtain the correct position.
Can you help me with some steps or an example ?
Thank you...
Using NX7.0 and TC8.1
RE: Override position
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I prefer use tools that are new and fully supported.
Thank you...
Overriding Constraints allows you to assign new constraints at the current level which will override those defined in a subassembly, but the overriding is done AT the current level (you never have to go inside the subassembly for any reason whatsoever). It also allows you to add multiple copies of the SAME subassembly to an assemble and yet position the components of one subassembly different than the others.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I've done what you suggest, but the concentric constrain between the rod and the cylinder it's override.
I would like as the mating condition.
I attach a video.
http://dl.dropbox.com/u/7283608/overridepos.zip
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
I remember that in NX3, the override position put the degree of freedom of the sub-components at the level desired.
For example if the rod of the cylinder assembly can move along the the rod axis, in NX3 with override position I can have the degree of freedom of the rod at the first level.
Now it seams that the coaxial between the cylinder and the rod is not calculated.
Thank you...
The trick is to make sure the constraints in the sub-assembly allow for the movement that you expect. All 'overriding' does is tell the sub-assembly that I want you to behave in the top-level as you would in the sub-assembly if your components were moved.
Anyway, look at my assembly paying particular attention to the way I constrained both the top-level assembly and the sub-assembly.
John R. Baker, P.E.
Industry Sector
Cypress, CA
your example works fine.
I've done as your example from always, but never work.
Today with your example I understand why.
The reason is because my cylinder sub-assembly had mating conditions and not assembly constraints.
Thank you...
As long as you do NOT attempt to override the 'Mating Consitions' in a sub-assembly added to an Assembly using 'Assembly Constraints' you're OK. But when you try to use 'Override Position' you are now attempting to make the sub-assembly's constraint model part of the top-level assembly's and therefore they MUST be compatible.
John R. Baker, P.E.
Industry Sector
Cypress, CA
