Beam calculations
Beam calculations
Beam calculations
Hi
first of can someone remind me how we calculate a beams deflection under its own weight? its beeen like 10years  since I left college and had to do any calculations...
I have a  large sheet of metal which has beams weilded in a grid fashion all over it and It got to be lifted and moved.
I have a limit on the number of lifting point i.e. four. I am considering using a section of the " uneven I beam" to do the cals as in use aguide. in the x and z direction in which the beams traverse.  The beams in he z direction are bigger.. Any advice from the people in the know would be great.
RE: Beam calculations
Figure out the beam's moment of inertia.  If it is simply supported on each side, the equation for deflection is 5wL^4/384EI, where w is weight per unit length.
"equation for deflection is 5wL^4/384EI" is right of a simply supported beam.  for a beam with many supports, "the number of lifting point i.e. four", you need something like the three moment equation.
