ID 3-phase ammeter?
ID 3-phase ammeter?
I found a 4.25" three-phase ammeter at a hamfest today, and bought it for a song.
Unlike much of the things I buy, I have an immediate use for this.
It has 7-segment displays for all three phases, some alarm limits & will show neutral current. It mounts in 3.97" circular hole. It's got a label with pinout & E142921 noted. It seems to run on DC of unstated voltage.
The controls are labeled C|N, Max/Min|Limits, Print|Prog &Set.
What it lacks is a name or model number of any kind. Does anyone recognize it from the photos here?
RE: ID 3-phase ammeter?
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
Thank you..!
{Wonder why are they ashamed of their name???}
Alan
First I'll need to figure out which power supply option it has....
And they're common as mud in utility substations around here.
old field guy
But I'll need to figure out the needed PS first; it can be 125V AC/DC, 24-48VDC, 120AC or 230VAC. A little circuit/component analysis should resolve that.
It works as represented and looks pretty, too. I can see why alehman's clients like them.
