Attaching the shear wall etension to an existing roof diagram
I designed this detail to provide shear wall extends to the existing roof diaphragm. (see attached). Is there a "liquid nail" or similar glue with approved shear values to be used as a replacement to the fastening from above the roof sheathing to prevent from disturbing existing roof cover? Is there a better way of continuous connection between the shear wall and the roof diaphragm?
Thanks!
If pdf attachment is not accessible, here is additional information:
framing:
Roof rafters 2x6@16"o.c. 16GA metal channels
wall studs 2x6@16"o.c. 18GA metal channels
#7 SD screw for roof diaphragm to blocking fastening
Thanks!
framing:
RE: Attaching the shear wall etension to an existing roof diagram
An expert is a man who has made all the mistakes which can be made in a very narrow field
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
I am going to try that hoping the inspector will take it easy.
Thank you again!
