NX 5: plotting a very large drawing
Hello all,
I am attempting to print a very large (~2 meter by 2 meter) drawing to full scale for my supervisor. The largest plotter where I work has a paper width of 34 inches. To achieve my goal, I would like to print the image as 4 'strips' and tape them together. Is this possible to do in NX 5 without trying to quarter it manually?
Thank you for your time.
Best regards,
Dan
Best regards,
Dan
RE: NX 5: plotting a very large drawing
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
create drawing with the entire size export it to cgm
import this cgm into a new file.
create a drawings with the max paper height of your output device. Split the height extension on extra drawings
plot and patch work them together.
That solution worked splendidly. Thank you again for your time.
uwam2ie,
I didn't try your method, but thank you for the suggestion!
