Anchor Bolt
Anchor Bolt
Eng design specified B7 Anchor bolts for Pre-Eng building on Water reservoir. Because of 1-1/4" size was long delivery item, contractor proposed Higher strength Alloy Threaded Rod(I am not sure but it was A7), which has better strength that B7 . Is it safe to go higher strength?
Rakesh
Rakesh
RE: Anchor Bolt
RE: Anchor Bolt
RE: Anchor Bolt
An expert is a man who has made all the mistakes which can be made in a very narrow field
RE: Anchor Bolt
