bleeder vent size and length
Dear Frineds
I have a 54 meter floating roof storage tank and i would like to know what size of blideer valve should i use ?what about it length?is there any refrences for it?
best wishwes
RE: bleeder vent size and length
Please tell us is not you in charge of this tank.
1. I assume you meant size, not length of the valve;- that should be determined by an engineer.
2. The qualified engineer able to determine the size of the bleeder valve would be able to tell you the references.
Good luck, don't give up your day job.
Cheers,
gr2vessels
