New unit in mathcad
New unit in mathcad
Hello everyone
does anyone knows how to define a new unit in mathcad?
I have to do a lot of calculations with the danish money called kroner (DKK), and it would be really nice if i could use such a unit in mathcad.
Thanks in advance,
Thanks in advance,
RE: New unit in mathcad
TTFN
Tata
That standard hidden area is in a "white board" sheet that I open whenever I want to just do some quick thing that I plan to throw away. If I'm starting something that I might want to keep, I open the whiteboard and rename it.
I tried to define the units (I think it was V13) using the published procedure, but it didn't seem to be worth it.
David
David
If you do it will re-insert a correcting term of (dollars / furlong), which is currency per length.
If only they would add the Angle unit, and a 'User unit', so that we could have torque in N.m/rad, distinct from Work in N.m, and I could distinguish Input referred voltages from Output referred voltages...
