Reverse Element Problem
Hi everyone
Sorry for bother you let me tell you that I working in a composite model using Patran and my model have perpendicular surfaces
So when I tried to put all normals vectors to same direction patran tell me
Testing for Reverse normals is indetermined a at shell branch. Do you want to proceed under the assumption that the elements meetings at a branch junction are not conected to each other
My question is how should I solve this? how can I put all normals vectors at the same direction ?
Thank you so much at all
I hope to keep in touch with you
Cheers
Julian
Cheers
Julian
RE: Reverse Element Problem
Onda
I will try to do what you adviced me in last answer so I think is it a great idea !
let me please to say you thank you for so much for help me I really appreciate
Thank you Onda
Warming Regards
Julian
