High Performance Steel
Does anyone have experience w/ or have some really knowledgeable references covering high performance steels? I've done some searches and found some information but I'm always looking for more. One specific question I have is if rolled shapes are produced in these types of steel. Everything I've seen so far has been plates for plate and tub girders.
RE: High Performance Steel
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Qshake
In general, the higher grades are only useful where the design is governed by strength, not deflection or buckling, and that's not most of the bridge. I've seen Gr. HPS 70W used most often for compression flanges in high-moment areas.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
