Assistance Translating Feature Control Frame to Layman's Terms
Hello All -
Within the attached drawing, there is a feature control frame highlighted in red. Can you please relay, in plain language, what this frame means?
Drawing: http ://files.e ngineering .com/getfi le.aspx?fo lder=b6796 7bd-10c0-4 350-a0e4-8 052407c601 a&file =Drill.jpg
Thanks for your time thus far!
Note: I have intentionally deleted some dimensions within the attached file as it is customer owned.
Drawing: http
RE: Assistance Translating Feature Control Frame to Layman's Terms
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Envelope (tolerance zone) has got diameter 0.35 not 0.3 when the toleranced feature is at its minimum material condition.
SeasonLee
To recap (just to be sure I'm understanding correctly), since there is an "M" (maximum material condition) in the feature control frame, this denotes that a bonus tolerance is permissible.
AT MMC: The tolerance window is simply as stated in the frame control frame. As stated above, at a 4.05 feature diameter there is a 0.25 dia tolerance window between the axis of the 6.18 feature and the 4.00 feature.
AT LMC: The bonus tolerance comes into play and at a 3.95 feature diameter, the tolerance window is 0.35 in dia. This 0.35 tolerance window is calculated by taking MMC-LMC (4.05-3.95 = 0.10) and adding it to the tolerance stated within the control frame (0.10 + 0.25 = 0.35).
Thanks, again!
Yes, you got it correctly.
Frank
Thanks for the question.
