Counterbored hole drill size.
I'm following PTC Academy tutorial. In the upper portion of the attached image I show the Tutorial views and in the lower portion I show my setting the same, except that I cannot get access to the through hole drill size?
The only way I have found to get around this is to turn off Add Tapping, but that is not what the tutorial shows?
Am I missing something?
In any case it seems to me that if you select Counterbore hole that the default behavior should be to go to a clearance hole rather than a tapped hole.
Wildfire 4
Wildfire 4
RE: Counterbored hole drill size.
hole_diameter_override yes
I must have missed that step in the beginner tutorial...
I'll get there. That is if I don't toss my computer out the window in frustration over variable section sweeps, blends... ...where is my Loft tool, ahhhhh
