Separating Circular part in Solidworks
I have a circular part which I created in solidworks. I want to split the part on one end and open it up x.x amount of degrees. This will be a molded part, and I am doing this for the mold. After the part is done, it should be able to come back into a perfect circle.
Problem is, I do not know how to do this to my model, or redraw it to show the split.
Any tips???
Any tips???
RE: Separating Circular part in Solidworks
Chris
SolidWorks 09 SP5.0
ctopher's home
SolidWorks Legion
You may be looking at some weird engineering. It sounds to me that your part must be some shape such that when you load it, it will bend itself into a circle.
Once you figure out what that shape is, you model it using SolidWorks' loft feature.
We spend all of this time learning to communicate with geometry - let's communicate with geometry. Attach your file here (if proprietary simply create a dummy file the exhibits the same behavior to illustrate your design intent).
picture a washer (made of a flexible mat'l of course), but I want that washer to have a split on one side and just wondering how to model that, so that when the washer closes back together will be perfectly circular, or cylindrical if you will.
create a new sketch, draw a line were you want it to split.
exit sketch, goto - insert - features - split
select the split line
push the cut bodies, let it assign names to the 2 new parts.
click ok
the new parts will be in the same folder as the original, just put the 2 in an assembly and put a degree mate on the 2 faces.
A first approximation would have a circular cross-section with the same thickness as the closed shape and inside and outside arc lengths which match the inside and outside circumferences of the closed shape.
Eric
