Help Annealing 409 Stainless Steel
I am looking to have expanded metal annealed that is produced from 409 stainless steel. The stainless is annealed then cold worked and now I need it reannealed after is is made into expanded metal. I have been searching but can not find any specifications for a time and temperature. The material is 18" wide, .15" thick and the coil is 500 ' long. I am lookig to have the entire coil annealed and back on the coil. I have been looking for a comapny to strand anneal but have had no luck.
