690rpm 17hp ac motor 35amp
can anybody tellme which company deal with this type of low rpm ac motor ? anybodyhold stock of these babies on us or euro ?
.Motor Trifásico Modelo BF5200l410
2.Potencia: 17 HP (12.6 Kw.)
3.Voltaje: 440 V.
4.Intensidad de Corriente Nominal In: 35 Amp.
5.Frecuencia: 60 Hz.
6.Velocidad: 690 rpm.
7.Grado de Protección IP: 56
8.Aislamiento Clase F.
9.Tipo de Servicio: S1
10.Temperatura Ambiente: 40 ºC.
11.Rodamientos: 6212 ZZ C3 (2 piezas)
12.Kg: 125
RE: 690rpm 17hp ac motor 35amp
This is basically just a 10 pole motor. 17HP is a bit odd, probably because of the conversion from it's original IEC 380V 50Hz design*. But if you need all the available torque, you could buy a 20HP, but if it was giving you more than you needed, you might be able to use a 15HP. Mounting may be an issue for you though, as it was probably metric and a NEMA motor will be US Customary System dimensions (inches vs mm). However there are plenty of US suppliers who will sell re-rated IEC motors like that, Brook Crompton is one that is(was?) widely available here, but you can get IEC frame motors from Siemens and ABB as well.
*If I had to guess, I'd say it was originally designed as a 380V 50Hz 10kW motor 10 pole motor. When you apply 480V 60Hz to it, it becomes 12.6kW because of the higher speed and same torque, then 12.6kW = 16.89HP.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
