GRIP to export all objects in layers
Hello all,
I have many objects in many layers and I want to export all the objects in a specific layer as a new part using  GRIP.Is it possible?
I wrote a GRIP from which  selected   objects are exported to files with the filenames defined by some attribute values and layer number.But I could not find a way select everything in the specific layer and export.
It will be great helpful if somebody show me some light on this!
thanks in advance
DineshNX6.0.2.8
RE: GRIP to export all objects in layers
Well of course it isn't perpendicular there was no reason given to assume that it would be. However if you simply thicken the faces based upon the original then you do get perpendicular faces. The downside would be those necessarily nasty looking conditions in the corners where the faces cannot be continuous.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Ignore the above while I um... post it in the right thread!
Best Regards
Hudson
www.jamb.com.au
Do you want to do just one layer, each layer one after the other, or layers according to defined categories. Any of the above might be possible using grip, but the first option you could do with a macro! Also be aware that if there are dependencies between object on different layers you will carry those objects with their children unless you conspire somehow to deliberately remove parameters.
Best Regards
Hudson
www.jamb.com.au
thanks Hudson for the quick response.
yes, I want to do each layer one after the other and there are no categories defined and parametrs  of the objects are removed.
Also I want to take the file names ( one stores the file location to be created) from two of my attributes and the layer number. This is the program I wrote
ENTITY/OBJ(25)
STRING/val(132),FIL(132)
STRING/PATH(132),STR(50)
NUMBER/RESP
NUMBER/LAYNUM
   FIL=&ATTVL(PART,'PROJECT',5)
   IDENT/'Select Objects to Archive',OBJ,RESP
   val=&ATTVL(PART,'File',5)
   LAYNUM=&LAYER(OBJ(1))
   STR=ISTR(LAYNUM)
   PATH=val+FIL+STR
   IF/RESP==3,$
   CPATT/PATH,OBJ
   HALT
this asks me to select objects. Is there anyway I can do a 'select all' like a macro?
thanks in advance
Dinesh
NX6.0.2.8
Your program will display a 'Class Selection' dialog and in the section titled 'Objects', if you expand it you will find a 'Select All' option.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
sorry for not being very clear.
I do not want to select anything. I want to just click a command and it should take care of making all the files in the layers.It should change the layers and select the objects in them and export as  files .
if I have 5 objects in 10 layers I need 10 files with each file having those 5 objects.
Another input I want to give is any layer will not have more than 10  objects.
thanks in advance
Dinesh
NX6.0.2.8
What you need to do is cycle through the part file, checking each object for it's layer status and then doing what ever it is that you need to do.  Look at the INEXTE and NEXTE commands.
John R. Baker, P.E.
Industry Sector
Cypress, CA
