Hidden lines appearing when zooming out on solid.
I've got a hollowed out part and when I zoom out then some of the internal edges start to appear on the outside of the part.
I've had a few people look at the file and some have the problem and some don't. We suspect that it might be to do with using dual screens.
I'm just wondering whether anyone else has experienced the same problem.
This is on NX6 running a March 2010 patch.
http: //picasawe b.google.c o.uk/10695 1149429721 788344/Unt itledAlbum #548107979 6960645426
http:
RE: Hidden lines appearing when zooming out on solid.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
This doesn't really bother us much, it seems as though it occurs as when you zoom out the geometry gets smaller but the line thickness of the edges remains the same so eventually the edges will show through thin walled geometry. Just a guess can anyone confirm this?
NX 7.0.1.7, TC 8.1
Preferences -> Visualization -> Faceting
...change the 'Shaded Views' Tolerance to something 'Finer'.
Also, if you viewing the model in Perspective you may want to reset the Clipping Planes using the 'Edit Camera' dialog.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I've found out that the problem also affects hidden-line wire frame. The hidden lines start coming through as I zoom out.
Take a look at this image for extreme case:
http:
Best Regards
Hudson
www.jamb.com.au
John R. Baker, P.E.
Industry Sector
Cypress, CA
Best Regards
Hudson
www.jamb.com.au
