Determination of pre-consolidation pressure by strain-energy method
Our laboratory only uses typical Casagrande method for determination of pre-consolidation pressure in conventional consolidation tests.  I am planning to introduce a second option and currently my first choice is strain-energy method such as Tavenas method.  There are two questions here:
1 – Does anyone have a comment in regard to using strain-energy method for determining pre-consolidation pressure.  Most of the published papers are calling it a more accurate and easier to use method.  I am wondering if you have come to the same conclusion in real life experience/project?
2 – I have read a few published papers on this topic and there are a few methods for strain-energy which are slight different.  However, in order to use it in practice, I prefer to use a method that is endorsed by a standard.  I could not find anything in ASTM.  Is there any standard that endorsed this method?
Thanks in advance.
Regards,  geoman110
RE: Determination of pre-consolidation pressure by strain-energy method
Have never used it - it is outlined in Bowles 5th edition.  Why not check out logp'-loge?  There are some good papers out there that show this method - results in two straight lines and the intersection is the pre-consolidation pressure.
Thanks for the reply BigH
I will check out the suggested method and also dig more into the Strain-Energy method.  I will keep everyone posted of the outcome.  Meanwhile, if anybody has more comments, it is greatly appreciated
Pacheco Silva's method from south america is also convenient to use and also independent of the graph scale.
Pacheco Silva, F. 1970. A new graphical construction for determination of the pre-consolidation stress of a soil sample. In Proceedings of the 4th Brazilian Conference on Soil Mechanics and Foundation Engineering, Rio de Janeiro, Brazil. Vol. 2, No.1, pp. 225–232.
I've told this story before - but Casagrande used to consult with my company back in the late 60s as our President at the time was a former student.  He came up to Toronto and an eager young engineer showed him all these beautiful Casagrande constructions he had done on quite a number of consolidatoin tests.  Casagrande looked at them and suggested a few changes here and there . . . the engineer asked him - "But, I did them according to your method."  Casagrande replied that, yes, you did but the construction method was developed to "teach" my students how basically to estimate it.
Hello everyone, thanks for the reply.
BigH, I am not sure if I understand the meaning of your story correctly.  Did Casagrande mean his method is just estimation or there is something else that I am missing?
In respect to the strain-energy method, I have done some research and so far it appears a good secondary/confirmatory method.  However, I am not done reading and cannot come to a final conclusion yet.  I will keep everyone posted when I have finished reading all the collected references.
In looking at the various different types of curves one gets in consolidation testing (what about those that aren't "straight" in the primary consolidation range) - a lot is a matter of judgment of which he had plenty.  How does one take experience and judgment and teach students?  You make up a methodology that will get the student, typically, in the right ballpark.  The construction method he developed and taught was simply that, a teaching tool.
Well said BigH.  Thanks for the reply
