Snow (Drifting and Sliding) on residential decks
I was recently reading a thread about snow on decks. The thread talked about what loading to use in this situation, but never mentioned the topic of drifting and/or sliding snow on decks. In lower elevation projects where snow isn't a big problem, there wouldn't be any need to worry about such. However, when working with projects for higher elevations, this could make a big difference in the engineering of the deck. Should drifting and sliding snow be taken into account when engineering high elevation decks, or simply just use the flat roof snow load?
RE: Snow (Drifting and Sliding) on residential decks
The only question is how much of the roof snow will slide in any particular situation.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
