NX6 - Visible in View
NX 6.0.5.3
Using visible-in-view, I make a layer visible. I then create some dimensions, selecting the geometry I made visible. When I now make the geometry invisible, my dimensions change to 'retained'.
Did something change between NX3 and NX6 ? Surely that behavious isn't correct ?
RE: NX6 - Visible in View
I also tested NX 7.0.1.7 and NX 7.5.1.4 with the same results, that is if I turn a dimensioned object OFF using Visible in View to the set the layer that the object was on invisible, the dimensions referencing the now invisible object are NOT changed to a 'Retained' status.
I tried this by saving the part, reopening it with partial loading, everything that I could think of which could possibly affect this and each time, nothing. I get the same behavior I verified in NX 3.0 (and NX 4.0 and NX 5.0 as well).
Sorry, I don't know what to tell you, but there has to be something more going on here than just a simple Visible in View changing the display status of a dimensioned object.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I'm thinking there's something else going on. I'll look further.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Mystery solved.
John R. Baker, P.E.
Industry Sector
Cypress, CA
It worked fine in NX3 and NX4.
