water retaining structures
what temperature of liquid is considered to be ok for standard designs. I am looking at BS8007 which states a temperature of approx 35 degree celcius. The equivilent Eurocode which we are now swithching to has a range of -20 to 200 degrees celcius. Why the massive disparity? 8007 is a dated (now withdrawn this year) code but still it seems a huge variation especially as there is little differnce in the amount of steekl provided (depending on cement type).
Any thoughts?
Any thoughts?
RE: water retaining structures
Why would you care about storing water at less than freezing and higher than boiling? Maybe in an industrial application?
