3D Connexion space pilot buttons
I have recently upgraded to Windows 7 and NX 7.0
Unfortunatly I have found that the buttons on my space pilot no longer can be programed to execute functions in NX.
Tech support from 3D Connexion can not offer a solution at this time. Has anyone else found a work-around for this problem?
Herb C.
Eifel Mold & Engineering Inc.
Plastics Tooling Designer
UG NX-6.0
RE: 3D Connexion space pilot buttons
Chris
L&M Tool
Lead Tooling Engineer
ug NX7.5.0.32
It is good to know that I am not the only one who has had trouble with this issue.
I have logged a IR with 3D-Connexion.
Hopefully they will fix this issue soon.
Herb C.
UG NX-7.0
Windows 7.0
I'm running Windows 7 on a Dell M4400 laptop and using a 'SpacePilot Pro' (in the office). The 3DConnexion software that I'm using is:
Release Version: 3.9.0
(Driver Version: 6.9.0)
Firmware Version: 4.10
Note that at home I use a 'SpaceNavigator' and on the road, a 'SpaceNavigator for Notebooks', all using the same driver software and I haven't had any problems with any of them (of course the SpaceNavigators have limited use of programmed buttons with only two, one of which I've programmed to bring up the 3DConnexion Control Panel and the other does a Display-Fit).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Are you running on a 32 or 64 bit OS?
Herb C.
UG NX-7.0
Windows 7.0
John R. Baker, P.E.
Industry Sector
Cypress, CA
