Failed the PE Again...Any Other Job Ideas For an EIT?
Well, results for the PE Exam were posted yesterday (for Texas anyway), and I've failed it for the fourth time in a row (by one question, same as the last time I took it). I blame myself for not studying enough (although our heavy workload has been at least partly to blame, and the lack of pure design work that gets sent my way).
But now I'm pretty much screwed, since the next time I can take it is in October 2011, and I'll have to take the new 16 hour exam. Meanwhile, at least one of my coworkers will be taking the exam and will most likely pass, further marginalizing my standing in the office.
Anyway, getting to the point; between this and other factors (such as the potential liability vs. salary issue) I'm getting disillusioned and bitter about my job, and I'm wondering if I'm just not cut out for this. I guess my question is whether anyone has any ideas about jobs that people with engineering training could do, or jobs that you've heard of that are conducive to a switch from engineering. I appreciate any input; thank you!
RE: Failed the PE Again...Any Other Job Ideas For an EIT?
Depending on your field, there are tons of jobs out there that do not require a PE. You can also look at transitioning to another area of engineering in an exempt industry.
What it may do for you, beside the personal achievement, is open more doors for you when you are looking for another job.
______________________________________________________________________________
This is normally the space where people post something insightful.
I'd encourage you to still keeping trucking and try to get your P.E., even if you want to move away from engineering. It will give you built-in respect when dealing with clients, and it helps in job search/advancement.
Maybe try the Civil PE instead of the Structural? The Civil PE is staying as an 8 hr test.
Two things can come of this:
1. You will see where you went wrong, pointing you in the area(s) you need to study; and
2. Heaven be, but grading mistakes are made, even by engineering professionals. You may find grounds for an appeal to the board.
In either event, the trip can't hurt.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
Tobalcane
"If you avoid failure, you also avoid success."
Don't lose heart. Failing the PE exam does not necessarily mean you are a bad engineer, it could mean that you are a bad test taker.
The test is geared toward solving problems quickly, understanding and applying first principles and knowing the footnotes in various codes (seriously!!). I took the exam back in April and my advice is to prepare for atleast 3 months. Know your AASHTO (I had a whole chunk of problems on Bridge) and I only design buildings. I can't emphasize how knowing to work around and look up bridge stuff will mean the difference between passing or failing the exam.
Godspeed.
I would suggest doing what i did, and taking a PE prep class (if you haven't already). it was hard for me to bite the bullet and sign up, but it was worth it. if nothing else it forces you to focus on studying. and by your own admission you didn't study enough. don't do the same thing expecting the differnet results.
Also if your workload is getting in the way, sit down and tell youre employer you need to focus on the PE exam and can only work a certain number of hours a week if possible.
final thought... if you're looking for a new job in this economy... good luck. i would focus on passing the test, exercise some patience, and once you pass in Ocotber reevaluate your situation. 6 months is nothing. At that time having your PE will be useful in making a job transition to something different. in the mean time talk to your boss and discuss what your goals are and what their goals are for you. it could help to improve your current situation.
I am going to see about appealing or having them recheck my exam form. If that doesn't work, I'm going to try going out of state for the October exam (since I've got to wait a year to take it again in Texas).
I also need to re-evaluate my study habits and come up with something better; I only wish there were better/more representative practice questions for the bridge/AASHTO stuff out there, because I can tell you that's one of the areas I got hammered.
Once again, thank you all for your input!
Regarding the study habits, I have an opinion based on my own experience (long time ago). I believe there is a definite % or number of questions per a subtopic or subject even within a discipline, that will appear in an exam. I am not a structural engineer, but in electrical there is power, electronics, industrial electronics , etc. Plus every discipline have something about economics and codes. Structural should have similar subdivisions.
I would choose only 2 or 3 subtopics you are comfortable with and which will provide you adequate number of problems to solve to make the grade, and work hard at those only, instead of trying to prepare for too many subtopics. Plus economics and codes should be relatively easy.
Also if the exam contains multiple choices, make sure you allow last 5-6 minutes just to go through all the ones that could not get to (leave out hard ones for this) and pick only one (from a, b, c, or d etc) of the answer for all of those. That way you have a chance to get 20 or 25% of them right. I do not believe there is any penalty for wrong answers.
Remember the goal is to pass the exam, not to show what area you are good at.
Rafiq Bulsara
http://www.srengineersct.com
If you are at an A&E firm I can certainly understand the pressure you are under to pass the PE. I have seen what happens to those who dont, they get pushed aside and end up designing parking lots and sidewalks or fighting tooth and nail to get into project management.
If the test was administered by the NCEES you can request they re-score your test but to my knowledge this has NEVER resulted in change from fail to pass. I took the electrical PE in Florida this last April, so it may be different in Texas or different for the structural test.
If it was me, I would take it again. Put in the time and study, buy all the PPI2PASS products, take a good prep class, testmasters and schoolorPE both have classes with a guarantee you will pass, work as many problems as possible, get the NCEES practice exam and again put in the time.
I work with two guys that didn't pass their PE until the 5th time, they get ribbed about it all the time but they are no less competent than those that passed it the first time. I don't know your study routine or how you have been preparing, if you have a nagging wife and 12 kids or if you just freak out on tests, but I think almost any engineer can pass the PE with the proper preparation so don't give up.
It took me 2 attempts to pass a similar exam with the IStructE. I didn't find it trivial.
It's often not a knowledge problem but more about exam technique and time management.
As advised above, take a prep class.
Others are OK.
Another thought is... have you had problems in the past with tests? Some people just don't know how to take tests, or get too upset, affecting their performance.
Mike McCann
MMC Engineering
Motto: KISS
One thing that was very irritating was that there was very little on the tests that pertained to my work. So basically, I had to go study stuff I hadn't used since college, and will never use again, and take a test over that, just to get the right to seal unrelated material. It's kind like making a brain surgeon take a plumbing quiz before he can practice. Or vice versa. In any case, you should have a pretty good idea of your abilities regardless of the test results.
I haven't researched it, but it seems like some states won't let you take the exams unless you live there- they expect you to get registered in your home state first- so watch for that if you look out of state.
Most experienced engineers ask the opposite: "Is engineering cut out for ME?".
For me, after having passed my PE in December, gone into a completely different profession working for myself (both by force but also by passion), I'm really starting to look back on my EIT years in hindsight and really it all boils down to the people and who is (if any, most likely not) is mentoring you.
When a young engineer says "I'm not cut out for this" that tells me his boss isn't encouraging to you. Shame on him.
That is one of the most ridiculous things I have heard in a long time. I don't know the OP's situation, but seriously, failing the PE exam 4 times? C'mon, something is wrong. Did you notice that his discipline is "structural"? What if he lives in one of those states where being a full-fledged structural engineer requires passing the Civil PE, Structural I, Structural II, AND state-specific Structural III exams. To be a licensed CE in CA, you must also pass additional state specific seismic AND surveying exams. If the OP cannot even pass the Civil PE exam, which MANY people I know personally have passed without even studying, how do you expect him to pass the SEI, SEII, and SEIII exams? It is time for the OP to look deep within himself and question if, in fact, he is cut out to be a structural engineer. Once again, this is not a cut-down of the original OP, because I do know of firms where their engineers are working 60-70 hours per week. Obviously, with this kind of schedule, there isn't enough time to study for anything, let alone find time to take care of their own personal affairs. So, I am well-aware that there are a multitude of "excuses" that one can legitimately use to explaining failing the PE exam. And I do know, as someone previously posted, people who needed 4 or 5 times to pass the PE exam who are just as good an engineer in in their respective disciplines as anyone else out there, including you and me. But we are responsible for ourselves, so to blame the OP's employer for lack of sufficient mentoring is not only ridiculous, it is unfair. You just passed the PE exam, so you know as well as I do that professional experience has little to do with success in passing as book studying and test-taking preparation does.
You state in your post, "For me, after having passed my PE in December, gone into a completely different profession working for myself (both by force but also by passion), I'm really starting to look back on my EIT years in hindsight and really it all boils down to the people and who is (if any, most likely not) is mentoring you. When a young engineer says "I'm not cut out for this" that tells me his boss isn't encouraging to you. Shame on him."
The work place not elementary school. Since when is a young engineer's supervisor also supposed to double as his personal cheerleader? Young engineers need to understand that they are responsible for themselves and their own destiny within the engineering profession.
Shame on you...
Have you considered a political career?
I have the Mechanical FE study materials (for my own interest...I have a perfectly good career in Canada), and I can honestly state that without *at least* several months of studying, at this stage in my life (30 years out of school), there is little chance that I would pass it with flying colours. I just don't solve problems *quickly* enough. Doesn't mean I'm a bad engineer...just means I'd have trouble passing an exam of that nature now.
Keep at it...study and sit the next one. Use the time lag to your advantage. Don't wait thirty years...
SNORGY.
I attribute my failure to different things, which include the fact that I didn't study enough. I could make up excuses about my work week or the fact that I'm out of town at least half of the week, but I won't, because it's my fault for not coming up with a way to study around it.
I did quite well on topics that were related to things that actually come up in work, which is why it's no surprise I had trouble with AASHTO, as I do not design bridges and will probably never do so. So the problem is figuring out how to study those topics effectively.
Just out of curiosity though, how did you get the idea that I was taking the Civil Structural exam?
Anyway, thanks again to all posters/cheerleaders/detractors.
I suppose the biggest challenge is dealing with the organizational nightmare that is the most recent AASHTO code (at least, compared to other codes). No excuses though.
As I recall, most of the design engineers working for the state DOT have taken the Civil exam (those who are young enough not to have been grandfathered in from pre-exam days, that is). And the state DOT has some pretty good bridge designers. I wouldn't sneer at any of them for not having taken the Structural exam.
Even the structural afternoon portion of the Civil exam can be a challenge for someone whose normal job duties don't really involve much design.
I do think it's legitimate to ask yourself if you're cut out for it--but doesn't your normal job performance, rather than an artificial test, give you a more realistic answer to that question?
Me, I took the Civil exam but I'm thinking about taking the Structural exam sometime in the future. I, too, do not do much in the way of direct design work in my job, and I am going to be entirely dependent on study materials rather than experience to pass the test--and there really isn't that much out there in the way of exam prep material for the bridge side. Especially the bridge side for the upcoming new format.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
I have to disagree with you in part here that "The work place not elementary school."
I, for one, would not have passed the tests that I did without the constant mentoring of senior engineers. If they are not mentoring their juniors, as far as I am concerned, they are not doing their job. That is what I constantly tgry to do here to the best of my ability, and I commend the OP for coming to this forum for advice. Never stop asking questions...
Although work is not "elementary" school, the teaching is an inherent part of professional growth, and an investment in the furure of the firm and the indivicual. There is no better place to get an education through experience than in the workplace. After all, remember that we all "practice" engineering. We ALL are always learning. Never forget that.
Mike McCann
MMC Engineering
Motto: KISS
I had the same problem with AASHTO. I never have designed bridges or do I ever care to do so. But my strategy during the test was to ignore the bridge problems and just focus on the building problems. During each part of the test I would have about an hour left after solving the building problems. I would use that last hour to scour the AASHTO code for the answers, and it still didn't seem like enough time but I got some right because I was able to spend about 10-12 minutes per problem.
I hope this helps.
Hg
That is not at all what I meant. I agree that mentoring is a very valuable experience for those of us that are able to receive it. And I do agree with many others that our younger engineers are not mentored as they should be, if at all... It seems now the trend is to throw young engineers into the deep end of the pool and leave them to sink or swim. Unfortunately, many are drowning.
What I meant by that statement was to address atleng's position that "...When a young engineer says "I'm not cut out for this" that tells me his boss isn't encouraging to you. Shame on him." All the encouragement and mentoring in the world is not going to help any engineer pass the PE exam if they aren't going to take it upon themselves and study. And I mean really study. If you have to take the PE exam 5 times -- you are not studying! I don't care what anybody says. What I meant is that young engineers have to take it upon themselves to study and no one can force them to do that. If the flunkee is not studying, then why "shame on him [the employer]?" That is what I meant when I said that his opinion was ridiculous.
The OP needs to find time to study, period. My response was meant in no way to disrespect the OP. It was just to point out to that as mentors we can provide all the teaching, guidance, and, yes, encouragement. But if our young engineers are not even motivated enough to sit down and really study and apply themselves to sufficiently prepare for the PE exam, that tells me they lack motivation. If you lack motivation, that usually indicates that you lack passion. And if you lack passion, then well, maybe you really aren't in the business you are supposed to be in.
That's all I meant...
Best of luck to you Joestar, really.
Eddie
I recommend spending time familiarizing yourself with the important chapters such as Ch 3,4,5 and 6. Make sure you look at the Table of Contents and Indexes to familiarize yourself.
You may find that getting 2-4 AASHTO questions right (which may be as simple as a code lookup) will mean the difference between passing and failing.
Test taking is all about the confidence you go in with. You cannot go into an exam confidently if you know that in the back of your head you have not touched AASHTO. Why take the chance when you don't have to?
This is my $0.02 having taken and passed the SE-1 in the first attempt last April. I must tell you that I had a good chunk of bridge.
Download this design aid for reference. It is super useful
http
Good luck.
Hg
http:
Also I found these snow load examples published by SEAW useful since I have never ever designed for Snow Loads
http
Go into banking. I hear when they screw up they get a bailout instead of a lawsuit.
Seriously.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
