Can't get past submitting and dont get any msg file.
Hello.
I just started using ABAQUS/CAE. I'm doing a very simple simulation, but got some problems on the way. First time i tried to solve the analysis i got an error message. It didn't say what was wrong it only said to look in the message file if it exists. However the file did't exist so i wanted to restart the analysis hoping it would go better this time. When i submitted the job it started to work. But the problem was at this point that analysis didn't get past the sabmitting phase to the running phase. I have tried many differet things to ty get it work, I have deleted the jobs, changed their nams etc. but nothing works.
Why don't the analys get past the submitting phase?
The msg file mentions:
NOTE: THE RATE OF CONVERGENCE IS VERY SLOW. CONVERGENCE IS JUDGED UNLIKELY.
ERROR: TOO MANY ATTEMPTS MADE FOR THIS INCREMENT
This should not accur since this is a very simle problem I am analysing and everything is linear.
Thank you.
/David
Thank you.
/David
RE: Can't get past submitting and dont get any msg file.
Tata
