When is a vessel required to be ASME designed and stamped?
What is the maximum pressures and temperatures a vessel containing water can be before it's required to be ASME Designed/Built and Stamped?
Max PSI = ???
Max Temp. = ???
RE: When is a vessel required to be ASME designed and stamped?
The ASME does not require any vessels to be stamped.
The jurisdiction in which the vessel will be installed / operated will set the requirements and excemptions for which code should be used.
jt
For the US & Canada, you should refer to the National Board Synopsis of Boiler & Pressure Vessel Laws, Rules & Regulations.
It is document NB-370.
This sounds like you're trying to ask a scope question.  The SCOPE of ASME Section VIII includes vessels above 15 psig.  But there is nothing stopping you from applying the Code to vessels under 15 psi.
jte is correct, though, you have to understand the rules that are applicable where you are going to operate the vessel.  The jurisdiction may require ASME vessels for your service.
If it can be exempted in your jurisdiction?  And only follow ASME:
Max PSI = 300
Max Temp. = 210 F
2007 ASME Section VIII Division 1
U-1 Scope
U-1(c)(2)(f)
Thanks for all responses this sight is a GREAT Resource
We have a customer who wants a Stainless Steel Vessel for Water that will be in the United States
With the Following Requirements:
Volume: 15 liters
Pressure: 150 PSIG
Temperature: 300° F
Does this Vessel require ASME design & "UM" Stamp?
Per the ASME BPVC VIII Div 1 - Rules of Construction.
BuffFan,
I believe the answer is yes however the responsibility belongs with the end user that they install and opearate equipment according to the local codes which can vary from state to state and could alse depend on the local city inspectors.
From a manufacturing standpoint it would be prudent to  verify this with the end user before the unit is designed and constructed.
BuffFan,
Whatever is the going around this hot topic, the answer is simple: yes, it is a dangerous pressure vessel which must be designed and fabricated to the requirements of ASME BPVC Section VIII Division 1. The stamping is optional or mandatory in accordance with the rules of the state you intend to use the vessel. In any case, you must receive from the accredited pressure vessel fabricator (not a shonky backyard manufacturer) the appropriate documentation and markings/nameplate in accordance with the code.
Otherwise, it's almost certain you'll end up in trouble with the law.
Cheers,
gr2vessels
