Rectangular or NonCircular Pressure Vessel per Appendix 13 of VIII-1
This is a couple of code questions regarding the joint efficiencies and allowable stresses of Appendix 13 of ASME BPVC Section VIII-1, particularly 13-7(a).
1. Joint Efficiencies. When a rectangular pressure vessel is built from 6 plates (2 top plates, 2 side plates, and 2 end plates), does that pressure vessel have "butt joints"? I assume the answer is no because the joints create corners.
If the attachments are, or are not, butt joints, how do I determine the efficiency of those joints assuming I have done no type of radiography or equivalent inspection?
2. Stresses. When looking at the Total Stress Formulas in 13-7(a)(3), what are the associated allowable stresses for each of the formulas given?
In the example problem 13-17(a), which runs through the formulas of 13-7(a), the code appears uses 2 different joint efficiencies and determines 2 different allowable stresses to compare against the calculated stresses. I need to know what allowable stress is associated with what calculated stress.
Thanks.
Thanks.
RE: Rectangular or NonCircular Pressure Vessel per Appendix 13 of VIII-1
2. The allowable stresses are specified in 13.4
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
